xm 2.1 stop solenoid
Matthew
Unread post by Matthew »
What is the voltage on stop solenoid. I undid injector line behind the pump and THERE WAS NO DIESEL coming out of there. Then I checked the voltage on solenoid with ignition on and i had only very small voltage (0.06 V) on the feed. Can i run direct feed from the battery to start the engine? This is lucas pump.
thanks Matthew
jeremy
Unread post by jeremy »
Is this car fitted with an immobiliser?
As far as I know stop solenoid operates at 12 volts - so can be jumped. Its probably best to disconnect it so you don't feed 12 volts into the back of the immobiliser which mnight damage it.
jeremy
x 1238
Unread post by Peter.N. »
Yes, I can confirm that the solonoid should have 12 volts on it. There is an emergency fuel cutout at the top of the o/s strut, check that it hasnt tripped.
Matthew
I energised the solenoid directly from the batery and the car started ok. However i must say the electrics are in very poor condition. How difficult is rewiring the lot?
Thank You for replies
jeremy
Matthew - I think if you are asking the question the answer is 'Impossible'
Probably there's nothing wrong with the wiring itself. Early XM's have problems but they are usually confined to the connectors and junctions and a good clean up and careful inspection may work wonders. Something like a contact cleaner as sold by Maplins may help.
jeremy
Matthew
Thanks. Then I am not going to rewire it.
Next question is: where is coolant fan motor thermo switch located, I presume on the thermostad housing. Secondly If the above is true, I have conector on thermoswitch but on both side of it there are 2 other sensors screwed into the housing but without conectors (ques the connectors are snapped) \\\\is this important?
x 1238
One will be the over temperature warning light and the other the cooling fan switch, I think! It isn't actually the thermostat housing as the thermostat is in the return pipe at the back of the engine.
