When the ignition is switched on the fuel needle seems to be going up and down erratically.
Any ideas
Fuel Gauge
Fuel Gauge
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
I dont know about these modern cars but in the olden days there was a variable resistor in the tank connected to a float and the resistor became 'noisey' intermittently making contact. There also used to be a voltage regulator that supplied the gauges that could go intermittent...but as I say that was in the days when you could understand how cars worked!
Just the fuel gauge nothing else.....RStacey wrote:Is it just the fuel guage or are there any other abnormal electrics?
It doesn't matter if it is stood still or moving it moves about 15mm up and down , it's really annoying me now
Anymore ideas ?
My BX TZD was doing that - the gauge going to full, then down to half and back to full, couldn't rely on it at all and finally it just bottomed out and wouldn't move. Pulled the sender out of the tank and the metallic eching on the circuit board had started to come off and was cauht on the float, so it couldn't move. I cleaned it up as best I could and it worked fine, but only down to a quarter tank and after that it wouldn't register as the foil was gone. Swapped it with the one from my parts car and it's 100% now. Not sure if the Xantia TD has the same sendor set up, but Haynes should show you where it is/how to remove it. If it is the same, has three wires from the plug on it - one is earth, the other two are the variable earth from the float and the 'empty' solid earth for the light on the fuel gauge. If you bridge across them or provide a solid earth, you will be able to see if the gauge goes to full and remains still.
cheers,
Roscoe
91 BX TZD
90 BX 16V (x2)
04 Peugeot 307
90 Mitsubishi Express Van (alpaca transport)
Roscoe
91 BX TZD
90 BX 16V (x2)
04 Peugeot 307
- PicassoPigeon
No - unless you remove the tank sender unit - or the fuel pick-up & filter assembly. But I guess a quick glance here could give you some ideas for a modification to do this.gav425 wrote:Can you fill the tank from any of these. Would be quicker to fill from here with my veg oil, takes some time with a funnel.
Anders (DK) - '90 BX16Image
