Need to change the front pads on my C5 soon.
I have used the two screwdriver method (one square shafted) to retract xantia pistons and have a retraction tool for the C3 rears (where the screwdriver method is difficult -the slots don't go right accross the face of the pistons).
I have heard that on the C5 the pistons need to be rotated in opposite directions to retract - Is this correct ?
I also assume the piston slots are as per the C3 ?
Any successful work arrounds for the C5 front to avoid buying a retraction tool with a lefthand thread ? I have not seen one anywhere so presumably they are rare and expensive (and probably Citroen)!!!
Fred
C5 front brakes
AndersDK
AlWilliams
Hi Fred1
UK Tools sell a left hand threaded brake cylinder retraction tool for citroens, I think its about £16 plus delivery.
You can order online at www.uktools.com and from experience delivey is usually next day.
Hope this helps.
Hope this helps.
ZX TD Volcane 133k
Several bikes (for when the car don't go)
Before you judge a man, walk a mile in his shoes. So when you do judge him, you will be a mile away and have his shoes.
Clogzz
- x 40
And here is at least some of it:AndersDK wrote:This has been discussed recently. Use the search feature.
http://www.frenchcarforum.co.uk/forum/v ... hp?t=16208
2002 C5 2.0i AL4 239,000 km 76372389
fred1
