If your 97 had the 3mm socket at the front....im guessing yours was the same as what i currently have.
Top model - CD changer connection (din) at rear and steering wheel controls
Below the top model - Steering wheel controls and an output "3mm" socket at the front (which is what we both have)
And then below that it has even less.
This is the "top model" which is the one im after unfortuantly the bloke doesnt know what age the car was that it came out of...if i came out of the newer xantias then the steering controls wont work with it in my car, however if it came out the first xantias (which is what i need!!!) then its all compatible!
That stereo is from newer Xantia MK2. Different connector for steering remote. Power supply cable would be same, standard ISO. Sweet looking stereo though.
