zx central locking
greatoaks
zx central locking
my 94 zx 1.9d has developed a fault with alarm and locking. It will not operate at all with the plip (new batteries) it will centrally lock with the key. as well as this the flashing alarm led stays on all the time but not flashing.
rabenson
greatoaks
rabenson
You can check your plip if you have access to a digital camera with an lcd display type "viewfinder". point your plip at the camera lens whilst looking at the display and you should be able to see the Infrared LED flashing when you press the plip. If not and the red IS flashing then I would definitely suspect a dry jont on the IR LED. Dead easy to sort out as I mentioned earlier.
Ron
Ron
