406 gearbox
smirnofff
406 gearbox
Unread post by smirnofff »
does anyone know if it is possible to swap the 406 V6 manual gearbox for a 2.5td manual gearbox?
i wish to improve the gearing on my car to gain a higher top speed.
would it be better to switch to the automatic gearbox?
which gearbox has the longest final drive?
and which is the easiest to swap?
i am in germany for the forseable future and higher top speed is more important than acceleration (which i have plenty of)
grateful for any comments
Guy
DHallworth
x 162
Unread post by DHallworth »
if you put a diesel box into a petrol car will it not be all wrong?
A petrol would rev much harder, so it might end up cooking the gearbox, not sure though.
I know you couldn't put a petrol box in a diesel car because the ratios' are all wrong because the petrol revs higher.
Not sure.
David.
smirnofff
diesel engined cars run at lower revs, but they still have to achieve a similar top speed. so if you attach a higher revving engine to a diesel gearbox the theory is that you will gain a great deal in top speed. the gearbox should easily handle the power as a comparable sized diesel engine gives much more torque.
the question is: will it fit?
