Hello,
Lost power due to (I suspect) turbo boost pipe coming adrift - can someone please tell me where on the engine to start looking? I have limited time available for research so a quick guide from you enthusiasts would be very much appreciated.
Many thanks,
John.
Xantia 1.9TD Boost
johnway
Xantia 1.9TD Boost
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
jeremy
Could be 2 boost problems, first being no boost, in which case check all the high pressure pipework from the turbo (in the exhaust) to the engine inlet manifold.
The second is that the thing is boosting n9icely but no additional fule is being injected. I'm not sure of the pump fitted to your car but certainly the earlier ones have a small pipe from the high pressure system to the injection pump and this pipe is prone to splitting and falling off. This is the more likely problem.
jeremy
- x 1238
