After spending hours trying to identify the multiplug pin numbers to test wheel sensors (No numbers on my multiplug), this info may help any other Xantia owner having similar probs.
Here are the pin numbers for Xantia td abs ecu (1994).
top row 26 - 37.............................26 xxxxxxxxxxxx 37
middle row 14 - 25........................14 xxxxxxxxxxxx 25
bottom row 1 - 13 (longest row) .01 xxxxxxxxxxxxx 13
1 & 6 f.o.s. sensor
15 & 30 f.n.s. sensor
29 & 31 r.o.s. sensor
28 & 19 r.n.s. sensor
11 earth
13 to abs relay terminal 30
16 earth
22 feed from brake pedal
24 earth
25 diagnostic socket
27 diagnostic socket
32 abs relay terminal 85
33 abs relay terminal 86 & 12v feed from fuse 6
37 diagnostic socket
