Peugeot 406 1.9dt r reg, management light came on and i had the fault code read, The fault was with the start of injection what ever that means.
I can get it started but it feels flat when driveing it and sluggish and doesnt rev up quickly, it also run hotter than it used too.
I can flicker the ignition on and off whilst its running and then it will run fine (Like Normal)until the revs are dropped down again,
Could this be a relay fault or fuel pump fault?
If relays which ones do i need to check?
Regards Lee
Please Please help! 406 1.9 dt not running properly
rich201283
