Zx TD Bad starting
classic2cv
Zx TD Bad starting
Unread post by classic2cv »
my better half has a Zx TD
when she starts it first thing in the morning it takes a good few seconds
on the starter together with a lot of chugging :(
it olny starts first time if you put your foot on the accelerator pedal
while turning it over then it comes to life in a big cloud of smoke :?
do we need new glow pulgs or is it something else
after the first start it's fine for the rest of the day :)
Curtis
martyhopkirk
Unread post by martyhopkirk »
Use the search function (top) and put in TD or D or ZX poor staring / wont start etc - various soloutions have been covered till the cows come home.
Likely culprits are:
Knackered glowplug(s)
Air Leak
Clogged Filter (fuel & Air)
Good luck - I had a problem on my NA ZX a year or three back - was an air leak in a pipe running under the CAV pump. New rubber & some silicone cured it.
My money on this one would be glowplugs.
yangreen
Unread post by yangreen »
Hi Curtis (at a guess!)
Sounds like glowplugs to me. Next time you do a cold start, try turning the ignition back off and giving the plugs a second blast before starting the engine to see if that changes things but ultimately, they probably need doing. Weren't too expensive when I changed them on my Pug with the same engine.
Ian
1986 Citroën 2cv Dolly. 133k. All shiny again!
1994 Citroën AX 1.0 Jive - girlies' workhorse GONE
x 1238
Unread post by Peter.N. »
If it starts up on only 2 or 3 cylinders and runs rough for a few seconds, sure sign of glow plugs, If it takes a lot of turning over and then starts on all 4, could be failure of the glow plug relay or even all 4 glow plugs, but thats unlikely.
mezuk04
Unread post by mezuk04 »
Last night I decided to buy some Glow Plugs as for a few weeks its been doing the big cloud of white smoke at start up when standing over night or during the day at work, glad i did - this morning was the first time it took a few seconds "twice" to get her started but not worryingly bad though.....its great cos its at pretty much the same mileage the ZX was when i needed to change the glow plugs on that...so hopefully things will be similar
Volkswagen Golf 59' 1.6TD S :(
