I am trying to fix a grinding noise from my Xantia, but my knowledge and skills seems to keep coming up short of a solution
On acceleration or at motorway speeds there is a grinding noise coming from the front end of the car. It is so bad you can even feel the vibration through the floor
* Changed both CV joints
* Changed a drop link with play
* Changed a track rod end and a track rod
* Changed the bolts in the spring assembly on the exhaust
* Repositioned the exhaust about 15 times, brand new by the way
The drive shafts seem rock solid, i.e. no play in the inner joints. I had a local independent loosen a track rod and he looked for any probable cause for the noise, but couldn't find any.. said it might be the lower arm ball joints, but that he couldn't find anything wrong with them..
Anyone with an idea where to start looking, pls.? I'm getting desperate and the rain is getting more and more dense..
