I am fitting a towbar on my XM but am wondering if the old standard way of hooking up the lights will interfere with the ecu. Is it necessary to fit relays? I was quoted $NZ1200 to make and fit a bar and lights ( with relays) to a car which cost $NZ1500! So I bought another car with a towbar for $NZ800, but it has no wiring connections so I have to find out for myself!!
I will make a bar myself (using one as a pattern), and will have to wire up the two cars. Some advice will be appreciated. Thanks, Ernie.
Wiring for trailer coupling; help please!
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
I'm just in the process of fitting a bar and electrics to my C5 estate and I've met with the same dilemma - whether to fit relays or not. Some say not necessary, others that it is. I've decided to play safe and fit them. Citroen also do a plug-in kit, but at a big expense, so I'm going to use blue connectors on the back of the bulbs. In the UK, making and fitting a towbar is illegal. Since 1998 every towbar now has to conform to strict EU approval, hence the cost of a bar has doubled in price.
- cornishbx16v
i got my local towbar man to fit my electrics and he didnt use any relays on the bx???? took him abut 5 minutes i think!
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16valve.co.uk
http://timmos.mysite.wanadoo-members.co.uk/
Its still not illegal to FIT your own towbar, its just that it has to be an EU type approved one if the car is post 1998., making and fitting a towbar is illegal. Since 1998 every towbar now has to conform to strict EU approval
If your car is pre 98 you can still fit non approved bars, or make your own if you want to!!
FWIW incidentally...
the XM's tail light plug-in pcb connections have a second parallel plug available where you can run another [spliced from a scrap yard donor] multi plug out of to connect the tow bar electrics/wiring. You may already know this, but I was well chuffed when I discovered it!!
- no nasty splicing of looms and awkward access etc...
Andrew
Andrew
Trailer relays
8) I'm overwhelmed!!
Thanks for the prompt replies. I will hook them up without relays for a start, it will be easy enough to add them later if necessary. I have a spare fuse board and relays out of a BX which I may try and adapt. I didn't mention that both cars are series 1 V6's; 1991 and 1993 models.
We are allowed to build and fit our own bars on private vehicles, I have seen some pretty dodgy looking ones at times.
Thanks again, Ernie
Thanks again, Ernie
horrid1
HI,
Found this in my Favs bin,
http://www.rydertowing.co.uk/trailer_to ... wiring.htm
Hope it is of help,
Greg
Hope it is of help,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
