HELP!! Suspect Broken Cambelt
zzf00l
Bad day today... can anybody recomend a Citroen Specialist (not a stealer) local to Sutton Coldfield, West Midlands. or...fancy having a go at fixing my 1.9td.... cash in-hand???
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
Previously owned
AX 1.4
zzf00l
Ian Fearn
fastandfurryous
- x 4
On a 1.9TD engine, remove the front cambelt cover. just the one bolt if I remember correctly, and jiggle it out of the car. If the belt is slack/missing, you have found your problem.
Could well be cheaper just to get a known-good second-hand engine rather than rebuild your current one. Depends on it's mileage, condition, service history etc etc.
This is not a signature.
- x 1431
zzf00l
dnsey
- x 19
yangreen
Timing chains? Nah, gears for me and my 2cv!
I hate cambelts. The Audi has one and I hate the flimsiness of the things. I'm sure companies actually fit them knowing they will reduce the lifetime of the car now that rust isn't such a problem and engines/gearboxes tend to last for ages. They have to design in something that will fail!
Ian
Ian
1986 Citroën 2cv Dolly. 133k. All shiny again!
1994 Citroën AX 1.0 Jive - girlies' workhorse GONE
Stinkwheel
Being the one that helped change the audi cambelt i agree, it was an amazingly thin, flimsy little belt that.
"Rust Never Sleeps" said Neil Young. Did he own old citroens?
1998 Xantia TD exclusive auto estate +3 x BX's +77' ami 8 break + 73' dyane 6 + '83 2CV6 + 94' XM 2.1 sx auto + 89' XM2.0i
+ '85' GSA + '97 XM 2.0 16v + '81 Visa super E
zxb29
zzf00l
Update...
Camshaft is in about 5 pieces, drive sprocket on end of camshaft has a huge crack!
Considering a 'broken cambelt repair kit' from Motorcast (£180) !!
Previously owned
AX 1.4
Previously owned
AX 1.4
fastandfurryous
- x 4
I wouldn't bother. Your engine will have had multiple piston/valve collisions, and the head will be scrap.
Most scrappies charge about £100 for a good 1.9TD engine, and you should be able to find someone to change the engines for you. It's less than a day's work to swap an engine, so you should be looking at under £100 for the labour to do that.
Or, have the head off and see how bad it is. You may be lucky and get away with a replacement head. (again, £50 from a breakers, and maybe £80-£100 to fit)
- x 1431
Bugger
You'll probably find that one or more of the camshaft caps is smashed as well, which is a right pain, since the camshaft journals are line bored and the caps and heads are matched pairs, and if you get new caps they won't necessarily fit. The best bet in this case is probably going to be to get another head, as this will reduce problems with bent valves, new camshafts etc.
Fit new glow plugs whilst the head is off!!!
classic2cv
i've had the same problem
all the parts inside the head get smashed to bits
it’s better to find a good replacement motor (£100 from a breakers)
Don’t forget to replace the cambelt, glowplugs & filters before you put it in
and change the belt every 40 to 45000 miles
enjoy miles and miles of reliable motoring
8)
zzf00l
Just an update! Finally got round to sorting the head.... Motorcast reconditioned my head (two slightly bent valves, broken cam) for £180.0 It came back like new, worth every penny. incidentally they can supply a brand new head for less than GSF charge for a recon. They also supplied a head set which included a head gasket (not like GSF). Also found the cause of the early cambelt failure. The Auxillary belt stripped an edge off itself and found it's way into the cambelt.
Previously owned
AX 1.4
Previously owned
AX 1.4
