ABS Warning Light
windysurferuk
ABS Warning Light
My ABS warning light came on last week for an hour then went back off.
It has now come on again
I have searched the forum and have the same symptoms as mentioned in a few otheer posts i.e brakes not working correctly when the light goes out or comes on whilst driving.
I have taken the wheels off to check the wiring and to look for anything obvious but couldn't see anything (apart from my missing handbrake cable!)
I have had a look in the BOL which says there should be a connector somewhere along thewheel sensor wiring but I can not see any connectors.Should there be some?
Also where do I check the resistance of each wheel sensor?
I took the connector of the ECU but didn't know if this was the place to check it.
The car is a R reg xantia 2.1 TD
cheers
cheers
dieseldes1
quick check!
ign. off disconnect ECU multiplug
resistance all 1000ohms
Front LH Pins 1 & 2
Front RH pins 19 & 20
Rear LH pins 5 & 6
Rear RH pins 22 & 23 Some models 21 & 23
Voltage AC 0.1V AC minimum while turning wheel
Front LH Pins 1 & 2
Rear LH pins 5 & 6
if you have an oscillascope you can check for an AC waveform across the terminals while turning wheel
This is a very simple check and unfortunately does not cover all faults!!
It sounds as if a sensor is faulty but could be is probably a faulty connector maybe even dampness as it has been really wet the last couple of days (well here it has been!!).
Des
Front LH Pins 1 & 2
Rear LH pins 5 & 6
Front LH Pins 1 & 2
Rear LH pins 5 & 6
Des
C5 2L 90hp estate 2001 118,000
Peugot 2L HDI 2000 82,000
Xantia 2 1.9TD Estate 1998 100,000 'oops' does not mate with BMW
Xantia 1.9TD saloon 1996 120,000 Sold
Honda CB450dx 1990
Honda CB450dx 1990
- x 1240
marco1
abs
hi had exactly the same prob 3 weeks ago was front o/s wheel dont bother with citroen they wont £90 for one a bit of wire and sender go to a scrap yard like i did £5...and niked another one ....and ecu!!!! trace it fom abs ecu ..i will try and find the link its so easy just need a multi meter and put it into pin holes ..sorry at mo cant remember numbers..iwill try for you ...job done
- x 1240
windysurferuk
jeremy
The sensors are not the same front and rear - have a look at the GSF site (shop and catalogue) and Eurocarparts - (same sort of thing) as I think the sensors are stocked by them.
Have a look at
http://www.frenchcarforum.co.uk/forum/v ... hp?t=16638
Have a look at
jeremy
windysurferuk
just disconnect ECU multiplug but don't seem to have any pins in the following places or am I checking the wrong end
Front LH Pins 1 & 2
Rear LH pins 5 & 6
Heres what I'm looking at. Pin one is marked in the bottom left hand corner but there is nothing at pin 2?
Front LH Pins 1 & 2
Rear LH pins 5 & 6
jeremy
windysurferuk
just done that but there are 14 thin wires 7 green and 7 brown. Even if i managed to pair them up I still wouldn't know which when to which wheel.
My only real option is to go to the scrappy and buy a front sensor and a rear sensor and try each one in turn??
My problem with this is I can see a way to disconnect the wiring on the sensor.
The BOL says to follow the wiring back from the sensor until I find a connector but I followed mine until it disappeared into the engine bay and can’t see a connector!
Any more ideas
cheers
Any more ideas
cheers
dieseldes1
I have tried to make sense of your photo of the multiplug along with the Autodata drawings and information, I will take mine off tomorrow and compare!
Des
Des
Honda CB450dx 1990
Honda CB450dx 1990
dieseldes1
The plug is on the abs Modulator control box on the n/s in front of the LHM tank! The photo you have taken is for the engine ECU ......
I have taken photo of the ABS plug which I will post when I get a few minutes to download from the phone, after the family things this afternoon
Des
Des
Honda CB450dx 1990
Honda CB450dx 1990
windysurferuk
dieseldes1
Sorry yours is an earlier ABS, I put your year and engine size into Autodata and that was the plug they gave, I had to go back to 96 and got the connections
F
15-30 L/H
1 - 6 R/H
Rear
19-28 L/H
29-31 R/H
All 1080 Ohms
Spin the wheels with the meter on AC and you should get a reading.
pin 1, 14, 26, all one side
Just shows never trust a manual!!!
or check the info before typing.......
Des
F
15-30 L/H
1 - 6 R/H
Rear
19-28 L/H
29-31 R/H
All 1080 Ohms
Des
Honda CB450dx 1990
Honda CB450dx 1990
windysurferuk
