I have been reading a bit about diesel engines running on vegetable oil recently and am intrigued at the prospect of converting my Xantia.
The problem lies with the model of fuel injection pump I have.
In order to have the 'conversion' work, I ideally need to have the Bosch type of injection pump and mine is currently the Lucas type.
The Xantia I have is a standard 1.9 diesel LX 1994 and has done 122k miles. I hope to arrange for a conversion (2 tank) to be in place but the Lucas pump is not fully compatible.
Does anyone know if the Bosch pump that resides on the Xantia 1.9Td or the one on the ZX 1.9Td will be a compatible unit with a standard 1.9Dlx or are the engines/pumps incompatible?
Also, should the pump be compatible, what sort of price do these things go for at scrappies? . . are they relatively easy to set the timing on once fitted? . . and more to the point, are they as rare as hen's teeth?
I live in the Uk (North West).
Thanks in advance.
Xantia Injection pump (changing from Lucas to Bosch)
BernieLugg
Kowalski
You'll definately need the injectors and injector pipes from the Bosch pump. Not all Bosch pumps have an ECU, I have one with and one without. If I was doing the conversion I'd be looking for a Bosch pump without the ECU.BernieLugg wrote:To convert to Bosch you will need all the injectors, pump, associated pipework and I think im correct in saying the ECU from the donor car.
fastandfurryous
- x 4
You should be able to find a Bosch pump and injectors from a 1.9TD enigne all over the place, for very little cash. Second hand injector set should be £15, and a pump should be about £40... Maybe £50 for the lot from a reasonable scrappie.
Suitable vehicles are:
Xantia 1.9TD without ECU
Puegeot 405 TD 1992 onwards (smooth dash model)
Peugeot 306 TD
Peugeot 406 TD without ECU (these are rare)
Citroen ZX TD
Citroen Xsara TD
And probably a couple of other obscure cars, but these are the main ones.
Although the injectors look identical to the Lucas 1.9TD ones, you must use the bosch ones, as the pintle spring is stiffer, and hence the opening pressure is a good deal higher... about 185BAR as opposed to 130BAR if I remember correctly.
Timing the injection pump onto your engine is fairly straightforward, but does require the use of a DTI (Dial test indicator). If it's not spot on, your economy will suffer, although (bizzarely) the engine will probably still drive just fine.
Peugeot 306 TD
Citroen ZX TD
Citroen Xsara TD
This is not a signature.
- x 1431
Hang on a mo guys.... this is a Xantia 1.9D we are talking about if I read the original post right? So it is NON-TURBO. In that case the manual injection pump from any vehicle fitted with the 1.9D engine will fit (eg ZX, 306, BX, 405 etc etc). However, are you sure it's a Lucas pump? All the Xantias I have seen / heard about have been Bosch (mind you they're all 1.9 TDs - the 2.1s have a Lucas EPIC pump I think). A Bosch pump without a boost compensator looks very similar to a Lucas pump (with or without a boost compensator). To be sure, check where the cold start cable runs to - if it's the front of the pump, it's a Lucas, to the back it's a Bosch.
tm1
James.UK
Why not just start using veggie oil as-is with no conversions, and replace the pump seals as, when, and if, they ever cause you a problem, it may never happen
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
tm1
Stewart(oily)
- x 35
I ran my Lucas pumped DTR for a long time on various concentrations of Veggie oil with no problems whatsoever, suggest you locate the parts, pop them on a shelf in the garage and get veggie
Stewart
Stewart
fastandfurryous
- x 4
A rather appropriate time for a rather loud, homer simpson style D'OH!RichardW wrote:Hang on a mo guys.... this is a Xantia 1.9D we are talking about if I read the original post right? So it is NON-TURBO.
In which case, the only thing you need to avoid is the early square-port engine, as it was a 65hp variant. Yours is the oval-port, at either 70hp or 71hp (I think it's something like 70.6hp, but gets rounded in different directions by different people along the way)
Square-port engines are found in Talbot horizon, 205, 305, 309, and early BX.
James.UK
Hiya TM1..
No. I am not running on veggie at the moment as I applied for a licence to use the stuff, turns out its so complicated and requires so many forms filling in that the annual saving simply isn't worth while in my case.
My ZX is only doing about 3.000 - 3.500 miles a year now at about 40-45 mpg, so I dont gain much by registering. My ZX did run well on the oil though, it performed a bit better all round, and even sounded happier on it, slightly less 'clanky' and a deeper engine tone.
I would have thought that any prob with the Lucas pump would have been leaking seals, I doubt the cam belt breaking would be the first sign of trouble should the Lucas fuel pump have problems with using veggie oil..
However, someone did mention you can replace the lucas pump seals for more robust ones that can tolerate oil use indefinately? so why not do that instead, it does sound the easiest solution..
I was also aware that Stewart(oily) ran a Lucas pump on veggie for a long time with no problems whatsoever. In fact I have never read anything about anyone on this forum having had a Lucas pump fail due to veggie use. It seems to be a theory rather than a proven fact.
But I would hate you to be the first.. .
lol.. So why not replace the Lucas pump seals..
tm1
Adstar
I'm just wondering what new seals will do for the pump? As far as I have read, fresh veggie oil is noone corrosive. It is the treated bio-diesel which eats stuff.
Any insights welcomed as I'm about to start the veggie experiement myself with a 2.1 TD 605.
605 Only an SL but it is a DT with a shake rattle and role!
Mk 1 MR2 waiting to have the final useful bits removed... RIP.
