BX Auto to Manual
Ian Fearn
BX Auto to Manual
Unread post by Ian Fearn »
Does anybody know what sort of job it is to swap over from an auto box to a manual box in a BX GTi 8v?
1983 2CV6 Charleston 110k (Re-build in op!)
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
1998 Xantia V6 Exclusive
yangreen
Unread post by yangreen »
Don't bother. Just bring it fording at the weekend in Bury St Edmunds, destroy it and then buy a manual one!
Or are you looking to buy one?
I quite like auto's myself although they need a big lazy engine (preferably V8) for maximum waftability.
Ian
1986 Citroën 2cv Dolly. 133k. All shiny again!
1994 Citroën AX 1.0 Jive - girlies' workhorse GONE
Ian Fearn
Up until 10 mins ago i fancied doing the conversion on a car i'd been offered.
The 4x4 BX is back on now but the same seller has offered me a red GTi 8v which i fancy even more!
Wish i could have both, know anybody who wants a red/black charleston?
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
alan s
RIP 2010
x 6
Re: BX Auto to Manual
Unread post by alan s »
Ian Fearn wrote:Does anybody know what sort of job it is to swap over from an auto box to a manual box in a BX GTi 8v?
FWIW, pretty straightforward I discovered when I supplied all the parts from a wreck to a guy who paid a specialist to do it and this guy quoted around 6 hours labour. However we did learn one thing with it and this was that if the car is injected, be sure to use the components from another injected car or you run into strife setting the Efi up as there's no place on the non injected cars bellhousing to mount the CAS and the gooses that did the job here weren't brave enough to drill the hole to mount it.
It would seem that the BE3 box is more likely to be a straightforward swap than a BE1 for tthis very reason but this could also just be a local thing as most early cars had the BE1 whilst the later ones had the BE3, having said that we still had early cars sporting the BE3 box, but just look for that hole and mount for the CAS regardless of the box being used.
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
BernieLugg
Unread post by BernieLugg »
Ian Fearn wrote:Wish i could have both, know anybody who wants a red/black charleston?
We have a saying in Yorkshire.... 'Ow much?
alan s
RIP 2010
x 6
I'm not even going to look north if this happens!!!!! :shock: :shock: :shock:
Alan S :roll: :twisted:
RIP Sept 19th 2008.
x 94
Unread post by citronut »
i did this quite a few years back,and from what i can remember there were no real probs,the car i did it to was an early 1.9 carb joby,it was not much more work than just doing a clutch
regards malcolm
yangreen
I quite like the Charlestons but yet again, any new purchases would probably result in a cancelled marriage!
Ian
jeremy
Unread post by jeremy »
Ah well Ian - its all a question of priorities - and starting as you mean to go! - Getting the Charleston?
jeremy
Ian Fearn
I would have no idea what to ask for this charleston!
I've spent the last year re-building it and its just about finished now. Mechanically its sorted, bodily its absolutely mint, probably one of the best original shells around. Fully re-sprayed (by me!!).
Needs things like tyres and a few bits of trim to finish off including re-spraying the bonnet.
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
