Xantia heater
Post Reply
Jshodgson
My Cars:
Xantia heater
Post by Jshodgson »
Hi all
now the weather is getting chilly I realise my heater is rather cool when set to the hottest setting. Any ideas?
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
BernieLugg
My Cars:
Contact:
Post by BernieLugg »
The heater matrix may well be gummed up and need flusing or replacing. Are you cerain the heater control is opperating the valve as it should to let hot water into the matrix, sometimes the cables snap/jam.
Use the Search function, as replacing the matrix has been covered in depth before, and i think the controls have also been covered - though are covered in the Haynes book.
Hope that no one has bodged the heater by "bypassing" the water pipes to fix a leaky matrix!
Good Luck
Stempy
My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX
Contact:
Post by Stempy »
I had a similar problem which turned out to be the a jammed open thermostat, meaning the coolant never actually got hot enough to heat the cabin efficiently.
Lexia ponce
np
My Cars:
Contact:
Post by np »
I dont know if you have one or not,but do you have a pollen filter?I know that in the summer if these get dirty or clogged the can reduce the efficency/coldness of the a/c.
53`406 est SE Hdi 140,110k
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1205
Post by Peter.N. »
It could be that the heater needs bleeding, especially if the hoses have been fitted the wrong way round. Disconnect the return pipe, take the filler cap off, run the engine and keep topping the reservoir up until water free from bubles is coming out of the pipe.
caeclyd2
My Cars:
Post by caeclyd2 »
np wrote:I dont know if you have one or not,but do you have a pollen filter?I know that in the summer if these get dirty or clogged the can reduce the efficency/coldness of the a/c.
Where is the pollen filter located?
My Cars:
x 92
Post by citronut »
pollen filter is behind the glove box,simple to check,you could also check the coolant level because if its low there wont be enough going up into the matrix,and you dont need to remove heater hoses to bleed the system
regards malcolm
np
My Cars:
Contact:
Post by np »
The pollen filter is under the glovebox.There may be a piece of carpet under there,so remove that,& then on the left hand side will be a plastic cover,held in by 3 screws.Remove the screws & plastic cover & pull out the old filter.I`m not sure if it only fitted to cars with a/c or not. :)
My Cars:
x 92
Post by citronut »
the plastic cover slides one way or the other,i think towards the center consel
regards malcolm
Jshodgson
My Cars:
Post by Jshodgson »
I now realise that the air is warm as opposed to hot at the highest setting. Does this mean anything that hasn't already been mentioned :?:
My Cars: Currently:
x 1205
Post by Peter.N. »
If the temperature can be varied the flap must be working, so assuming there is some airflow there must be a restriction in the water supply to the matrix.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
There may be air in the heater, instead of water.
The top heater hose has a bleed screw to let the air out.
2002 C5 2.0i AL4 230,000 km 76372389
Jshodgson
My Cars:
Post by Jshodgson »
Thanks,
how od I locate the top heater hose? And is the bleed screw one which can be tightened by hand?
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
The hose goes from the thermostat housing into the firewall.
As you look over the engine from the front of the car, it is to the left of the LHM tank, disappearing behind the engine into the firewall.
The hose is over 1 inch thick and is the highest placed hose at the rear of the engine bay, just where you want it to trap air.
The nozzle has a serrated button to turn by hand, and also has a slot in the middle to insert a flat-bladed screwdriver.
There are differences depending on the model and vintage.
It might be an idea to prompt for the opinion of the experts, who know all the variants, even looking the other way.
Post Reply
