ignition zx
victor xt
ignition zx
Unread post by victor xt »
Hi again mates, my zx 1.4 motronic has a little problem in the ignition. With the light sun on the car at 30 celsius degrees the car can't start, i hear nothing and then i swith the key off and then ignition and the car starts with no problem, what can be wrong here?
cheers
Clogzz
x 40
Unread post by Clogzz »
Probably the ignition switch.
The sun is beating down on the switch.
Copy of a post by Anders:
It seems you have a rather common intermittent cable/connector problem somewhere in +12V feed from battery or fuse box.
It could simply be your ignition key switch on it's way out - a known problem on ANY car.
Try it out :
have car parked, handbrakes on, engine idle.
Rev the engine some (don't race it !) - to have vibrations on the car from the engine.
Then try gently fiddling with the ignition key - avoiding the starter position - simply tremble/wriggle gently on the key - insuring the ignition switch is just exactly disturbed.
2002 C5 2.0i AL4 239,000 km 76372389
