Found it !!
ayden
Found it !!
Unread post by ayden »
I found the suspect area thats letting water into the 305 i started investigating after finding a lake in the footwell :shock: it is under windscreen near where the wiper motor is ill put some pics up when i get back from work. if it keeps leaking do you reckon it will rust the floorpan under the carpet ?
85 ' 305 SRD estate - scrapped
92 ' Fiat uno speed machine - scrapped
00 ' Citroen synergie HDI "the beast" - still going. . . . just
94' cavalier
lighteninguk
Unread post by lighteninguk »
one question i ask is are you sure its water and not anti freeze?
ZX 1.4I 1993 Reflex KDX
ayden
unless anti freeze smells like water ? :lol:
im pretty sure it is water
94' cavalier
James.UK
Unread post by James.UK »
Try prising the rubber windscreen seal back with a small blade and spraying some silicone sealer in at the same time, it cured my ZX and its been fine ever since..approx two years now :)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
ayden
Ive got some piccys (cant remember which way you have to tilt your head to see them properly though lol)
Not for the faint hearted
http://i15.photobucket.com/albums/a385/ ... /leak2.jpg
http://i15.photobucket.com/albums/a385/ayden17/leak.jpg
94' cavalier
