my xantia wagon (auto) failed to start after stopped for petrol. when a cable is linked from the battery '+' terminal to the starter directly and with the ignition key at "on", the starter turns and the engine fires up. what could be the problem? I was told that it could be either a faulty ignition switch, a faulty starter relay or the "gear inhibitor switch" malfunctioning. after searching forum, it seems it is highly likely to be a faulty ignition switch, if that is the case, can it be repaired?
http://www.alllinuxcd.com
xantia starter not turning
jeremy
dieseldes1
First thing to check is the exciter terminal on the starter motor, I have lost count of the number of Peugot/citroen cars I have been out to where all the terminal needs is a clean up (some cases cable terminal replaced),
check there is voltage on the terminal when the ignition switch is turned to start.
Des
Des
C5 2L 90hp estate 2001 118,000
Peugot 2L HDI 2000 82,000
Xantia 2 1.9TD Estate 1998 100,000 'oops' does not mate with BMW
Xantia 1.9TD saloon 1996 120,000 Sold
Honda CB450dx 1990
Honda CB450dx 1990
tj
problem solved! it was the ignition switch alright, it was duely replaced and the car starts normally. one strange thing though. before the ignition switch was replaced, i started the car by jumping directly from the battery and drove around, but the auto box refused to shift up from first, it jerks on first and lost drives intermittently. after the swtich was replaced, the gear box problem dissappeared as well. any possible explanation here?
406 V6
