having recently purchased another xantia diesel
Basically has anyone one got any suggestions of things to look at to try and improve the mpg.
TIA
Deano
The short answer is that the catalyst makes no difference to the MOT, diesels don't need a cat to pass an MOT.deano wrote: Kowalski, how do you get on with the MOT tests having no cat? or do you put it back on?
A chap I know has a Pug 405 1.9TD, and knew someting was wrong (he had kept mpg records for the last 6 years) as his mpg was falling (48 to 42-ish). It was only when the exhaust actually started blowing and he had it replaced his MPG suddenly jumped back to 48 (bar the first tankful whilst was "sooting" back up!).Kowalski wrote:Binding brakes are the obvious thing, but a blocked exhaust can cause a suprising drop in fuel economy, I replaced the catalyst on my '97 Xantia with a non catalyst pipe and the economy improved by about 5mpg.
