Intercahngeable starter motors (from 405)?
sdcoomber
Does anyone know if a BX starter motor will fit a Pug 405 TD? What are the differences between the BX16 petrol starter and the BX17TD?
Curiously addicted to them!
jeremy
- x 3
Diesel engines are very heavy to start due to the high compression (22.1). In the late 1980's starters with a reduction gear were introduced by (Mitsubishi?) and I think these were fitted to the BX TD before the N/A diesel engines.
I would expect a diesel engine starter to be a more powerful and robust unit than a petrol one but so far as fittings and teeth numbers go I have no information.
jeremy
Stewart(oily)
- x 35
All of the diesel starters are interchangeable between 1905/1769 diesels and TDs there are apparently some differences but I have never encountered them, and as a bonus the old sierra 2.3 diesel pug 505 one will work but will crank slower due to not being geared, I cut an old petrol engine starter about to make it fit a diesel engine once but it lacked enough power to spin the higher compression diesel engine.
Stewart
Stewart
Dave Bamber
