Xantia Clutch Change
Ian Fearn
Does anybody have a link to a Xantia TD clutch change topic?
1983 2CV6 Charleston 110k (Re-build in op!)
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
1998 Xantia V6 Exclusive
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
Dave Burns
This is an awkward job if on your own even with an engine hoist, even more unpleasant if you only have a trolley jack, you also ought to have an engine support bar to hold the engine up while the gearbox mounting is removed.
You want the lhm tank out the way so thats also a good time the to change the oil.
Get the BOL and follow it, don't try to unscrew the gearbox mounting stud its self, unbolt the casting that it is screwed into instead.
Remove the clutch cable anchor bracket and also the gear linkage anchor bracket that is bolted to the back of the diff, these two items will search for something to get hung up on.
Tie the regulator up well out of the way.
Don't forget to pull the pin from the clutch arm/release fork shaft or the box wont slide off, when its off its dowels it needs to be rotated to clear the subframe, the main reason a trolley jack is best avoided in favour of overhead lifting gear.
On refitting, test the operation of the clutch arm before getting too many bolts back in, alignment of release bearing and fork can be awkward so test to see if it feels right before continuing.
Dave
Dave
cobra427
plastic clip on clutch pedal
The plastic clip on the clutch pedal itself has split, hence leaving me stuck ingear on the mway in rush hour traffic last week.
Can some one tell me just how the heck I can get at the clip with out taking out the streering.
