NOISY HDI FUEL FILTER
lawns
x 3
Unread post by lawns »
Hi all,
My Xantia 110 occasionally has a loud metallic hammering noise coming from the fuel filter Housing on the engine.
I think the noise it is related to the lift pump in the tank as it has the same pulse frequency and stops when it does.
Has anyone any ideas on cause or cure as its getting worse?
mcgregor
Unread post by mcgregor »
After reading this I wonder if that is exactly what I have as well. See my post on "yet another problem".
Dave
Rostami
Unread post by Rostami »
A very commom failure on HDi models is the failure of the fuel pump, places in the tank. My guess is that your pump is packing up. As you can see, when it fails, your car will be immobilized :(
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
pikecrazy
Re: NOISY HDI FUEL FILTER
Unread post by pikecrazy »
lawns wrote:Hi all,
Mine had the same noise , i replaced with a new filter housing as i could not remove the top to put a new filter in and the noise stopped .
It seemed to be very blocked :oops:
All noises have stopped now from the housing and pump in the tank :D
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
x 1044
Unread post by wheeler »
i agree with that,change the complete housing & filter,this should sort the noise.
