Here's an odd situation with the CX that I can't work out.
The PR ticks at about 30 second intervals, and all the hydraulics seem to work almost perfectly. However:
If you try the sit-in-the-boot test after turning the engine off, it refuses to move. The back end drops about 8-10" when I sit in the boot, but then just stays there regardless of how long I leave it.
But... if after switching the engine off, you sit fairly still in the drivers seat, and push the height lever to max, the front of the car jumps up about 2", and the back 1", indicating that there was a fair bit of pressurised fluid available.
So how come the back won't react on it's own?
Accumulator sphere / "sit in boot" check method.
fastandfurryous
- x 4
This is not a signature.
Mandrake
- x 694
Re: Accumulator sphere / "sit in boot" check metho
8 to 10 inches ??? The suspension doesn't have that much travel from top to bottom let alone middle height to bottom.fastandfurryous wrote:Here's an odd situation with the CX that I can't work out.
What is the difference in time delay between you turning off the engine and sitting in the boot vs turning the engine off and moving the lever ? Perhaps if there is a pressure leak by the time you get out of the car and walk to the back there is no longer enough pressure.But... if after switching the engine off, you sit fairly still in the drivers seat, and push the height lever to max, the front of the car jumps up about 2", and the back 1", indicating that there was a fair bit of pressurised fluid available.
Also if your weight (and don't take this the wrong way
What happens if you lift an object into the boot thats a bit lighter, say 20-30Kg ?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
jeremy
fastandfurryous
- x 4
well, it's well over 6" for sure. I will measure, just out of interest. But remember that a CX has more suspension travel than most Cit'sMandrake wrote:8 to 10 inches ??? The suspension doesn't have that much travel from top to bottom let alone middle height to bottom.![]()
I also think it's riding a bit high, so there's more downward travel available than there should be.
Hopefully not too much different. I have tried waiting about 30 seconds in the car before moving the lever, and it still reacted.mandrake wrote:What is the difference in time delay...
I don't think I'm completely bottoming out the suspension, but being a rather large bloke (under tall, not over weight!) this may have something to do with it...mandrake wrote:Also if your weight (and don't take this the wrong way) is completely bottoming the suspension, What happens if you lift an object into the boot thats a bit lighter, say 20-30Kg ?
From memory, yes it does. Certainly the height correction both front and rear seems very accurate, so I don't think there's anything mechanically faulty.jeremy wrote:Could the height corrector linkage be stiff? - does it rise with the engine running?
A little more investigation required.....
