I have had a leak in the fuel system before (205) and as explained in the other sites visited, when starting it's difficult because of air (not fuel) in the system.
Once sorted the car runs OK. Then after a long stop air creeps into the fuel line and the circle turns again.
If the pump is trying as hard as it can to supply fuel during a trip then maybe the pressure is sufficient to start a leak of fuel.
When you say 'Got bad after run to Somerset' do you mean the running during the trip or the leak?
The leak will not get better so maybe the split is getting wider causing MORE difficult starts and more fuel leaks.
I would have a good look between the fuel tank top (under rear seat?) and the engine. Use the leak to help you locate before you move the car.
My money is on a rubber> steel pipe junction, where the rubber has the most bend and least flex. If so, chances are there will be enough rubber to rejoin the steel after cutting out the split length.
GIVE THOUGHT TO SUPPLY OR RETURN PIPE. DON'T DROWN IN DIESEL, WELL NOT AT ALMOST £1 PER LITRE!!
