The alleged problem in transition from mineral to semi-synth and back is one I've heard touted before and I suspect is one of those old wive's tales that stem from the days of vegetable-based racing oils. If you swapped over to a veggie oil, you couldn't change back without some form of flushing because the two oil were non-miscible and would lead to all sorts of fun problems at bearing faces. This isn't the case with modern mineral and synth oils.
Having said that, can I suggest that manufacturers, in recommending oils for use in their engines, have half an eye on servicing costs for the end user? If their engine requires a megabuck lubricant every few thousand klicks, then word'll quickly get around that the car's costly to service. Therefore, there's going to be a degree of compromise at the R&D end of things that can be eradicated if the end user's prepared to shell out the beer tokens.
Certainly I've seen 'cheap' oils that have degraded to the point of uselessness fairly quickly after 'missed' oil changes, while their more expensive counterparts have simply soldiered on pretty much intact, protecting the engine pretty much as they should.
One of the things that always sticks in my mind is an engineering lecture I attended at college (back in the days of gas lamps) when we were thrown the question, "How does an oil at, say, 40psi gallery pressure, protect a big end bearing under shock loadings of hundreds of pounds?" The answer wasn't in pump pressure but in
flow because, provided there was plenty of (healthy) oil at the bearing, centrifugal force at the crank ensured the oil arrived with enough force to maintain bearing seperation. If the oil was too thick, then it didn't arrive in sufficient quantity to indulge in its little 'fling'
Strewth! .................... did I just woffle all THAT??
