Strut tops
Ciaran
Strut tops
Unread post by Ciaran »
Ok, today I got the car jacked up and the wheels off, and got a good proper inspection of the wheel arches, instead of just the casual poke I'd had before.
I touched the rubber on the underside of the passenger side strut top.... and horror.... got the dreaded crunchy sound :o
The rubber 'looks' ok, but it is starting to perish a little. There was a slight bit of rust behind it at the front, about 1cm in size. The rest of it is sturdy and non crunching... for now.
I guess my question is how long do strut tops generally last ? Are there any signs that they're very close to the end, and should not be driven on ?
I'm not currently getting any knocking sounds or odd behaviour, and the car is sitting level at the front.
I'll now be looking to replace both sides I guess :(
Anyone done it ? Is it a hard job ?
Any thoughts appreciated :)
x 94
Unread post by citronut »
sorry to put a downer on things but its likly not to give you any warning,it will just pop up through to say hello
regards malcolm
Ciaran
Nice :)
I saw a few XM's with bonnet blisters... I really want to avoid that :)
Is it possible to buy just a strut top ? GSF only seem to do the entire strut... and I'm still reeling from the £142 PER SIDE price tag :(
x 94
dealer only im afraid,also they are model specific,look at my posting on the tops i replaced for one of my customers
regards malcolm
Ciaran
s**t :(
What kind of money are main stealers looking ?
x 94
i cant remember but the cost was in my post on this subject,look up posts by (citronut) me,strut top update there is some picys
regards malcolm
Ciaran
Cheers, will have a look now :)
I presume a dodgy strut can only really be seen by pressing the rubber and seeing if it crunches. Can the rubber be removed for a thorough inspection of the metal ?
x 94
i wouldnt because the metal dome is moulded in rubber,and there is a big chunck of rubber on the underside of the dome,if the rubber is breaking up the weather gets in to the metal,so the metal deteriates
regards malcolm
Ciaran
I only checked from the underside of the wheel arch... the top of the strut, I can't see any rubber on :shock:
The metal dome is shiney and new, as the car had new spheres just before I got it...
x 94
the shiny black bit is the sphere mount,the top of the dome is below that,although the strut top and sphere mount is all one unit
regards malcolm
Ciaran
Thanks for that, will have another look tomorrow.
I'm still looking for the thread of yours with the pics... will be interesting to get some gen on it :)
c7rlf
Unread post by c7rlf »
It's a bit late now I suppose :? But when I got my current Xant Dribbled Waxoil around the strut top just for peace of mind.
I did try to keep of the rubber though :shock:
Formally known as PARANOID
x 94
unlikly waxoil will hold back the enevertable,as the bit that goes is moulded inside the rubber,so when the rubber starts to crack wet gets in and coroudes the metal, i had a prob finding my tread on this,then found it by just doing a search for author(citronut),the scrolling through to find strut top update
regards malcolm
ps.
my IT expert is at uni so i do strugle
x 1464
Here's the thread:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=14883
I couldn't make the search engine find it either, other than searching on citronut and scrolling through. Seems to have a mind of its own - must be a Citroen :P
Clogzz
x 40
Unread post by Clogzz »
And here's where it started, 3 pages:
http://www.frenchcarforum.co.uk/forum/v ... highlight=
