ZX Boot Lock Solenoid
- x 1464
The boot lock on the ZX unlocks no problem, but it seems to have lost any ability it ever had to hold itself in the locked position. After a short drive or opening the boot a couple of times it drops back into the locked position, necessitating a lock/unlock cycle to get in the boot. Anybody know if it's possible to dismantle and repair, or do I need a trip to the dealer and hand over some body parts for a new one? (In which case we'll probably just live with it!)
jeremy
I think the hatch door lock motor may be the same size as the generic ones sold by Maplins for about £7. There are 2 types - a 5 cable and a 2 cable. The 5 cable is for a front door with a key lock and the 2 cable for a back door without.
I had a 5 cable one fail on my BX and thought I would fit one of these - I was expecting to have to reposition it on the door frame and make a link from the rod provided - so imagine my surprise when it bolted straight in and the existing rod fitted exactly - which leads me to wonder if all these things are much the same.
While I've never taken the one off the ZX I have had the lock out of ours and the motor looked similar to a door one
jeremy
rabenson
redfrus
citroenbx
On my way to the breakers tomorrow..My ZX locks but will not unlock.
The noid was weak when i tested it.
I got a replacment solanoid from a ZX at the breakers but found the holes didn't match up,so be carefull here.
Luckily i think in the B/Yard there has a 95 model but it does seem Citroen changed the way the noid was mounted through out the years.
TIP: Take your old with you.
Cheers
Cheers
Life feels good just as you complete No4 Glow Plug on a ZX-TD
