Airbag
Post Reply
j_roc
My Cars:
Airbag
Post by j_roc »
Evening to all. Have any of you guys and girls heared of the airbag "G" sensor. Im told that if the car decelerates within a set limit (i.e like a crash situ) then this "G" sensor triggers the airbag. Where abouts is the sensor on a 1995 Xantia lx. Thanks all the same - Alex.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
Inside the airbag control module, mounted on the steering wheel.
That's why it's got to be handled with due ceremonial when it's removed to take the steering wheel off.
2002 C5 2.0i AL4 230,000 km 76372389
j_roc
My Cars:
Post by j_roc »
Ah I should have put it's technical name down - a deceleration valve (think it's spelt right? :roll: ). So it's in the center of the wheel then. Thanks clogzz, much appreciated - Alex.
Sir Clive
Post by Sir Clive »
OK then chaps, to take this one stage further...how do you take the steering wheel off without getting a faceful of airbag :shock:
I'd like to do this job on the C5, to straighten the wheel up after its visit to the dealer to have the new column fitted. I can't take another half day off work while they mess about with it.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
Don't know about the C5, but with a bit of luck it will be similar to the Xantia, that I have had cause to do several times.
Look behind the steering wheel to see where the airbag mounting screws are.
Probably that it will look like the steering wheel will have to be off centre by 90 degrees to reach them.
That gets done while the power steering still works.
Next, disconnect the battery and wait for about 10 minutes to discharge the airbag back-up battery.
Next is to unscrew the airbag and disconnect the airbag plug, it pulls outwards.
Loosen the steering wheel lock nut a few turns, and gently rock the steering wheel free.
It may take some time, but it's better not to force or to cause impacts.
Then remove the steering wheel lock nut and rotating earth connector ... no rocket science ... seeing is doing.
At reassembly, it's no use overtightening the nut, there's no risk of it escaping, and it will be easier for next time.
pie eater
My Cars:
Post by pie eater »
Try getting the tracking reset at your local tyre fitters, one with one of the laser setups. Quite cheap, never really a waste of time and the steering wheel can be set dead true while the're at it.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Eunos Roadster (I'm sure theres enough room under the bonnet for that HDI)
My Cars:
x 92
Post by citronut »
adjusting the tracking will not centre the steering wheel,when its been put out of line by being removed,adjusting the tracking just alters the toe in/out of the road wheels
regards malcolm
pie eater
My Cars:
Post by pie eater »
Yes it will.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
j_roc
My Cars:
Post by j_roc »
Make sure that the steering wheel is in the straight ahead position, then set the wheels (tracking) to that. - Alex.
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
I'm with Citronut on this one.
What has happened is that Sir Clive has had his steering wheel removed and refitted so that it is no centered any more the problem is that the, steering wheel was removed and not centered, so the fix is to remove the steering wheel and to center it properly.
If you try to fix it by adjusting the tracking, you will end up with one track arm longer than the other, at best you might find that you have more steering lock in one direction than in the other, at worst you'll find your car steers for you when you go over bumps.
fastandfurryous
Location: On the road, travelling at high speed. Meep Meep.
My Cars:
x 4
Post by fastandfurryous »
If the steering rack is not centred properly you may also find that the car pulls to one side all the time.
This is not a signature.
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1204
Post by Peter.N. »
To check if the wheel is correctly centered, turn it on to full lock in one direction and then in the other, the No of degrees of rotation should be the same in both directions, if it is but doesn't steer straight, THEN adjust the track rods.
Dave Burns
My Cars:
Post by Dave Burns »
Airbag controller is under the console forward of the gear lever.
Careful handling is required beacuse its an explosive device, deployment of which under the wrong conditions can be fatal.
Dave
Post Reply
