Feeling brave?
yangreen
Feeling brave?
Unread post by yangreen »
http://cgi.ebay.co.uk/citroen-bx-gti-4x ... dZViewItem
Had a transfer box 1500 miles ago. Should be good for that again!
If it wasn't for this forum (in original guise), I might have bought one of these a while back...
Ian
1986 Citroën 2cv Dolly. 133k. All shiny again!
1994 Citroën AX 1.0 Jive - girlies' workhorse GONE
fastandfurryous
x 4
Blimey! he want's top money for it too. Reserve not met at £500 spells an un-sold car to me!
Anyone nearby enough to go and take it for a test-drive, and see if his spline drive is in one piece?
This is not a signature.
Sl4yer
Unread post by Sl4yer »
The mileometer looks a bit misaligned.... :shock:
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
bxbodger
Unread post by bxbodger »
I woudn't worry about the odometer being misaligned- that seems to be a BX trait!!
Mine does it all the time, at the moment its straight, but It'll click over another random digit and all of a sudden it'll look like Arfur Dailey's been at it!!
nick
Unread post by nick »
bxbodger wrote:I woudn't worry about the odometer being misaligned- that seems to be a BX trait!!
The trick with BX odometers is to slap the top of the instrument panel with the palm of your hand a couple of times, this often makes the numbers line up properly. Well they do until you next drive the car, then they'll go out of line again.
bxbodger
No, thats how you get the blower to start!!!
tanto
Unread post by tanto »
not there any more message states item removed by ebay
1996 xantia sx 2.0L 16v
if at first you don`t succeed get a bigger hammer
yangreen
Maybe he said it was reliable...
DoubleChevron
Unread post by DoubleChevron »
DON'T DO THAT Image Image Image Image Image
Your hand will go straight through, then you'll be screaming abuse at the car for hours while you try to glue all the mess back together with super glue (trying to get the dash into at least 4 or 5peices .... just like before :lol: :lol: ).
seeya,
Shane L.
'96 Big BX 2.1TD exclusive slugomatic (aka XM)
'85 CX2500 GTi Turbo Series II (whoo hooo)
'96 Xantia VSX slugomatic (sold !!)
and of course, lots of old Citroens, slowly rusting away in pieces ;)
nick
DoubleChevron wrote:Your hand will go straight through, then you'll be screaming abuse at the car for hours while you try to glue all the mess back together with super glue (trying to get the dash into at least 4 or 5peices .... just like before :lol: :lol: ).
Ah, but it makes it easier to change the heater matrix :wink:
Kowalski
Unread post by Kowalski »
Delisted, but now relisted against a different item number?
nick
The ebay withdrawal was due to the extra wording in original advert 'not golf, mondeo ' etc
Sounds as though ebay have started cracking down on this trick often used to get an item to appear in more search results.
