Please can someone with the same type of vehicle as mine(1994 Xantia
1.9TD sx with ABS,no aircon) confirm to me what rating of fuse thet have in the fuse box next to the ABS ECU.It would be in postion 5, or, if you look down at the said fuse box,viewing from the front of the car,it would be the 6th fuse looking from left to right.
The fuse I have in this position is rated at 5 amps which I believe to be wrong as the fuse supposedly feeds the radiator cooling fan(s) and therefore should be rated much higher.
I think someone in the past has replaced this fuse incorrectly.
Your help much appreciated and thanks in advance.
Stevie
