Factory recall: The dealer put on a steel-bowl underneath each front spring to prevent a collapsing spring in rupturing a tire (Concord-style?
My C3 has started to rattle or rather make a clonking sound when I pass speed bumps etc.
First I thought it was a loose plastic cover or something, but I can't seem to find any (engine bay or underneath) which is loose and I am starting to suspect some suspension component. A quick test showed that the clonking sound appear if I stand beside the car and rock it from side to side..
Being a complete ignorant on suspension bits (usually end up replacing lots of perfectly good parts :oops ) I was hoping someone could give me a good hint which bits to suspect and check ?
