Clutch replacement on a Xantia
Fox
Unread post by Fox »
My car has done 147,600 miles, and ever since I got it the clutch biting point has been right at the end of the travel - I hardly need to move the clutch down to change gear.
Is the clutch on its way out, or does the pedal need adjusting? The day we got the car the clip snapped, and was repaired before I'd ever driven the car - my father says he noticed no problem with the clutch when he test drove the car the day before the pedal slapped prior to purchase. Does it just need adjusting? I sometimes get 'juddering' when changing gear at speeds below about 35mph.
If, as I suspect, its due a new clutch, how much would I be looking at for the whole job at a citroen specialist? We'd do it ourselves, but its apparently a very long job and we just don't have the time at the moment.
Cheers!
1994 Citroen Xantia SX 1.9 Turbo Diesel
147,500 miles
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
To check the adjustment of the clutch, measure from the centre of the foot pad to a point at the low edge of the steering wheel. Depress the pedal to the floor and measure again to the same point on the wheel. Take one measurement from the other, and the difference should be 150mm. If it isn't do the adjustment at the clutch end of the cable. If a new clutch is required, and you don't fancy the job yourself, why not try one of the clutch centres. A Citroen dealership will charge the earth!
Fox
Thanks for your advice :)
What sort of price would I be looking at from one of the clutch centres? We've got a place called Clutchcare nearby actually - would I be better taking it their than one of the independant citroen specialists?
147,500 miles
adrianeaton
Unread post by adrianeaton »
Not sure what a clutch replacement place would charge - but if they're anything like the ones we tried to get to replace the clutch on a BX 16TRS a few years ago they'll all want a fortune 'cause they don't like working on hydraulic Citroens! We ended up doing the job ourselves and the kit cost about £50 at the time.
A Citroen specialist will be by far your best bet - they'll be able to do it quickly and minimum fuss. Post where you are in the UK and someone will suggest a reputable specialist in your area. I would've thought a clutch change wouldn't be more than about £200.
Adrian
Adrian_Mc
Unread post by Adrian_Mc »
I,ve been looking into this recently because my 1.9D Xantia Estate has a slipping clutch and its at the end of the adjustment. It's supposed to be a seven hour job to replace a clutch on a Xantia, I suspect that would mean about three days for me. I struggled to find many clutch centres in the Coventry area, there seems to be only one left. They quoted about £400. The AA service centre (ex Halfords) quoted £500+. But a local dealership which has just stopped selling Citroens but still services them quoted me £350 inc VAT today, although they did say the price on the screen was £580 but they never charged that because it was too excessive. I also found one clutch centre in London who provide online quotes and they came back with about £250 inc VAT, but they were too far away to use.
They were www.clutchdirect.co.uk.
Hope this is helpful.
shaunthesheep
Unread post by shaunthesheep »
i had my cltuch replaced two years ago by a fitting company calledhttp://www.mrclutch.com, they did the clucth + replaced the anternator/hydralic/water belt for just under £300.00, the price for the clutch alone was £229.00.
i don't reckon prices have changed that much <img src=icon_smile_big.gif border=0 align=middle>
hope this is of some help for you
dom
Mike1703
Unread post by Mike1703 »
Just had this job done on my new Xantia [P-reg TD] In Poulton, the seller got it done for £230 @ a Citroen specialist. The best price I could get in Liverpool [the local block & tackle merchants - they do a lot of damage!] was £265.
