mezuk04 wrote:Ok just got home and tried to check the colour of the lhm fluid, sadly my finger isnt long enough, yes i realize my problem in life now.
Well used a clean screwdriver and put the contents on to some tissue, its yellow, now originally its supposed to be green and brown means time to change, so does that mean yellow is half way there???
Looks like you have the same problem my car had - someone has put the wrong oil in the tank, so you have a mixture of two different oils. LHM does not go yellow under any circumstances, it goes from bright green to dark green, to dirty brown to black. (The latter two only in cases of extreme neglect)
Most likely it is a mixture of ATF and LHM. On my car if I dipped my finger in the tank and wiped it on paper as you have done it also looked yellow.
However after draining the system to put new LHM in and pouring some of the old oil into a glass jar and holding it up to the light I could see that there was about 3mm of green oil floating at the top, and the rest was dark red.
Whatever the red oil is, it does not mix with LHM, the LHM floats on the top, so when you look in the tank you will most likely see the green oil that is floating on the top, but dipping your finger in gives you a mixture of the two, thus the yellow colour.
I would suggest that you syphon about 100ml out of the tank into a glass jar and hold it up to the light to find out what colour it REALLY is, as I found looking down into a tank (and also into the bucket that I drained the old oil into) did not show me what colours were really there.
Assuming its not proper green LHM then I would advise you change it ASAP, as there are a number of different oils that are red, some of them potentially damaging to the system, and none of them will behave exactly like LHM for the functioning of the system...
One change I notice on my car since the change is that it lifts much more quickly in the morning now.
Also this cover was loose ontop of the battery and the lhm tank, not exactly sure where its from.
That looks like the cover for the fuse box ?
Regards,
Simon
