Confused? I am!
trailer_park_boy
Confused? I am!
On trying to remove the rear arm on the Xantia, I stumbled on a problem - The circlip that holds the rear arm to the suspension link rod (the lever that goes into the hydro unit) has snapped off (somebody been fiddling before me thinks) leaving a fair bit inside. The result is that I cant seperate the rear arm from the suspension link rod. Do you think it would be ok to drill the rest of it out? - Thanks all the same - Alex.
j_roc
sleepy0905
j_roc
j_roc
- x 94
just buy a rear arm bearing kit,it has all of the parts you require,except the shim washer and rear arm,kit cotents two bearings,two seals,two spacers,one pivot bolt and nut,steel bearing suport sleave and a plastic linner,i put a blob of weld on two of the inner side of the outter bearing race,to aid removal,then just reassemble
regards malcolm
ps. GSF sell the kits
regards malcolm
j_roc
