106 help needed <new pictures>
yokopol
Unread post by yokopol »
Iam new here.I`ve just have bought 2003 Peugeot 106 and I think some thing is missing in my car. I have no idea what is it, take a look at the picture and maybe someone will know what is it. It is on the left side of engine and on it there is part number # 028 906 283f. you cansee pictures at:
Mosser
Unread post by Mosser »
Hmm, i recognise that as a boost bypass valve for a Seat Leon, its called an N75, its also used on the audi, VW, and skoda 1.8 turbo petrol engines
Unless your car has a turbo, i cant see what use it would be, it has a small diameter always open bleed airway in it, and can be opened up fully by the solenoid attached to it or simply modulated to allow a certain amount of air past it, they are controled by the ECU and run at about 75Hz usually
I have no idea why its on your car or what possibe use it could be, it isnt even made by peugeot !!
Mosser
In fact, after looking at the picture again, i can even see the audi logo on it !!, its the 4 circles slightly overlapping each other !!, so its an audi part
bikeboyz
Unread post by bikeboyz »
Why is the wing where its bolted on looking uneven?
CITMAN
Unread post by CITMAN »
looks like to me some dodgey accident repairs have been carried out. Correct me if im wrong
Peter D
Unread post by Peter D »
What engine is in your car. ?? And I agree what is all the uneven metal work. The part is a A3/B4 TDI “N75” boost regulation solenoid (1Z, AHU engine). 028 906 283F Regards Peter
