Renault Scenic(2004)Clutch pedal,
SRID
Unread post by SRID »
Hello there,on my scenic 1.9 dci(2004),the clutch pedal is higher than the brake pedal,by about an inch,although the clutch doesn't slip,and I can get the gears ok,was wondering if this was normal,as I thought the pedal should be about the same height as the brake.is this reason to go back to the dealers after covering 9000 miles,any info would be appreciated,thanks.
TazzyK
Unread post by TazzyK »
i think it is normal for the clutch pedal to be slightly higher than the brake pedal on any car
