405 non starter
duggie
405 non starter
Unread post by duggie »
The glow plug heater light on the dash fails to come on and the car refuses to start, is there a fuse or relay that could have failed? any other ideas to solve this problem (matches, petrol come to mind)
Cheers.
Duggie
Stinkwheel
Unread post by Stinkwheel »
My old Cit diesel did this, the fuse that controls the light had failed, causing the glow plug relay not to work.
Try that first, think its a 20amp one.
duggie
Checked all fuses, all seem ok, think i need to replace the relay, anyone got a bosch unit for sale?
Stinkwheel
Are you competent with electrics? You could run a lead direct from the battery positive (a heavy duty one) to the positive feed of the glow plug relay, hold it there for few seconds then try start car. If this works not main glow plug relay.
duggie
which is the positive terminal on the relay?
Stinkwheel
may be difficult to see but usually the big thick wire but they should be marked underneath.
fastandfurryous
x 4
You need to check a few things to do with the relay unit. There should be a multi-plug, and 2 heavy cables. One of the multi-plug connectors is a feed from the ignition. Bypass this straight from a battery live, and see if the relay clicks. This will tell you a fair bit about whats wrong.
