Cambelt
Dave Bamber
Jimmydeath
If the engine is similar to the ZX TD engine then you can lock the flywheel with a metal dowel, I cut the head off a bolt for this, through a hole in the block behind the starter motor. I have achieved this without removing the starter motor however I would say that it is far easier to undo the three bolts and remove the starter first.
The bolt used is the same size as those that lock the camshaft and fuel injector pulleys, 8mm if I remember correctly.
David W
John,
You don't have to lock the crank, it is just the best way to ensure the position is accurate and maintained throughout the belt replacement. It is sufficient to mark the position in a way that is easy to see and double check the crank hasn't moved before setting up the new belt. I never rely on the locking pins/makers marks but add my own in white paint to be absolutely sure.
David
David
Jimmydeath
David W
James,
Sound advice. I hesitated to describe the method without locking pins as it does need absolute confidence/experience bearing in mind the potential result of any error. I am mostly the first person to change the belt on vehicles I maintain so am quite happy that the settings were correct from new. Thanks for the thoughtful correction to my post.
David
David
