my bx diesel estate,when fully cold pauses for half a second or so then turns over would this be the starter or battery?
cheers Ray
bx diesel starter or batt?
jeremy
Could be either - so measure battery voltage - should be 12.4 - 12.6 in the morning after standing overnight. Observe meter while operating starter and if it drops much below about 11 volts its battery. Now start engine and see what it charges at. Should be between about 13.8 and 14.6 if all is in order. If it is not suspect alternator.
Starters often temporarily improve if they are hit! - frees a brush - which will stick again in due course.
Jeremy
Jeremy
czenda
- x 1240
jeremy
- x 1240
Rob Marshall
jeremy
An electric current will always follow the path of least resistance so if the power available to the car is limited by resistance in a battery terminal operating the starter will tend to make everything else stop or go dim as the easiest path is through the starter motor and there isn't enough available for the higher resistance bits like bulbs.
If al is well the battery should be able to power lights, wipers etc while the starter operates. Some are wired so that some components are isolated while the starter is operating presumably to make more resources available for it.
Hence the common test of battery health - see how much the headlights dim while the starter is operating.
Jeremy
Jeremy
Jeremy
Jeremy
oilyspanner
bernie
a_seebo
ssray
AndersDK
