I have a P reg Xantia 1.9TD and recently the stop and (!) light have been coming on together. It gives the helpful advice in the manual that I stop immediately and call a citroen dealer.
It looks to me (and given that it's a citroen) like an electrical problem.
The lights are coming on at the same time and flickering/staying on/going off completely randomly (independant of revs/lights/braking/speed/gear etc etc). If it is electrics where should I start?
I also know that the hydraulic pump is leaking very slightly but then the lights should come on and stay on, or go on at low revs right?
cheers
Al.
STOP and (!) light
STOP together with (!) generally means a hydraulic pressure problem.
Whats the LHM level like ? Is the car rising Ok ? Does the light come on if you push the brakes and steer, or steer while the car is rising, for instance ?
On my XM, both of those were always on at startup, however they would flicker and gradually go out as the car lifted. Generally, they should not be on unless theres a problem.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aljohnso</i>
No because the accumulator sphere provides backup pressure.
It could be this which has gone though.
cheers
Al.
Where is it leaking ? If it has an output side leak it may have an intake side leak as well drawing in air.
There are two things that can cause that light to go on (both sensors are wired in parallel) - low oil level in the tank as measured by the float sensor which has a copper disc and a pair of contacts.
The other is the high pressure switch (located in the safety valve in the main high pressure supply line) which comes on when the regulator pressure is below approximately 100 bars. (Normal operating pressure is 170 bars)
First thing to check is the float level - and just to be sure you're checking it correctly, you are setting the suspension to full height with the engine idling and waiting for it to fully lift before taking the reading right ?
To try and seperate which sensor is giving the fault indication you could temporarily disconnect the wires to the float level sensor and take a short (!) drive and see whether the flickering persists. If it does you know the problem lies in the high pressure side, and if the pressure is dropping enough to trigger the stop light during driving you have a serious problem.
Next thing I would try is to check for signs of a leak causing the pump to suck in air - set the suspension to low, open the 12mm bleed screw on the regulator, and while the engine idles, peer through the top of the LHM tank filler with a torch and look for signs of bubbling or frothing. If you can see either chances are good that the intake to the pump has an air leak. Not seeing bubbles is not conclusive that there ISNT a leak however.
Regards,
Simon
cheers
Al.
Regards,
Simon
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
I have to agree with oilyspanner on this one... your first check should be the LHM level. Don't take any notice of the float.. i had the same symptoms for 6 months... took it to 2 different citroen main dealers and they couldn't find a fault.. thought it was electrical...eventually took the car to an independant small garage.. ex citroen mechanic..and he found the fault straight away..low LHM and a stuck float... and from then on he does all my servicing.
level check as you have said but with car on level ground
regards malcolm<i>Originally posted by Mandrake</i>
cheers
Al.
Regards,
Simon
[/quote]
cheers
Al.
Regards,
Simon
[/quote]
