Xantia 1.9TD 1995 Sunroof
soupy_sam
I have a problem with my electric sunroof it will tilt fine but it will not slide open the motor drops the tid and then starts to go back for about half an inch then it will not budge. Any Ideas please
Ciaran
soupy_sam
wrinklet1
jonnydrumm1967
Try helping the roof to go back with your hand while keeping the switch pressed.This worked on a 405 estate I had a while back. Copious quantities of lithium grease were sprayed throughout the runners and that was it.It worked fine after that. Mind you, make sure it's not gonna jam in the open position![:(]
wrinklet1
D.Slatford
soupy_sam
- x 94
wrinklet1
The Glass removal is easy, Tilt the sunroof up, then you will see some Torx headed screws, those are the ones holding the glass sunroof in place. Before you undo them, mark around the framework so you know where to put the sunroof back when refitting.
Paul
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
