ZX Purflux Oil Filter where now ? FOUND EM
After reading the forums re-oil filters i took a trip down to GSF to buy my servicing items..Shock ,Horror they dont have a Purflux Filter for my ZX-TD.
Worse than that they are not sure when they will be getting any more ?
Does anyone have a source for these filters.(Apart from Citroen Think of a price then double it ££££££)
Many Thanks.
Many Thanks.
It isn't really going to make any difference at all is it! - After all how often do you hear of an engine siezing from any cause at all or wearing out either. You like the look of the Purflux and think its the best but has anyone done a comparative test to destruction using the other filters? Even if they had and the Purflux came top the others would probably do a job that meant your ZX would have been crunched many years before it came an issue.
jeremy
jeremy
I think you should read this before deciding on a filter
http://minimopar.knizefamily.net/oilfilters.html
Thanks for all the advice so far...Not done an oil change yet on the ZX.
There seems to be some debate as to which filter is best ?
Great Link from James.UK
The FRAM filters do not score very well and this is all my GSF and the local Andrew Page are selling at the moment.
Looks like i may have to go to Citroen (think of a price and double it £££)for a quality oil filter.
I'll let you know- my BX has one on right now, along with one of the Auchan 2 euro diesel filters........
In the Triumph 2 litre six world,if you have a spin on filter conversion an anti-drain filter is regarded as essential to engine survival, but I'm not so sure how important it is on a newer design of engine.
If you order GSf ref N12047 then that is a Purflux or Citroen boxed (with Purflux filter inside) filter. N12045, the equivelant, is likely to be Lautrette brand. Incidentially, Lautrette do have OE as filter suppliers to Citroen and Peugeot, and they provide the factory fit oil filter element for the 1.4 and 1.6 HDi's.
