electric window relay
widget
Unread post by widget »
I have a zx 14i and the electric windows dont work i want to find the relay i know it is behind the fuse board but wich relay is it nothing in the workshop manual
AndersDK
Unread post by AndersDK »
I believe the ZX still have the BX style laylout of the fuse/junction box. Then it would be the rightmost/leftmost relays for front/rear window winders.
It would be standard 30Amp relays with a single make contact.
x 94
Unread post by citronut »
have you checked the simple things like fuses and if there is power to the switchs
regards malcolm
widget
thanx for reply guys i have only had the car a few days today is the first day to have a real look . It turns out to be the fuse board no power going to the 30 amp fuse for the windows and sunroof i put a link from another 30 amp and it all works just have to find out why there is no power going to try amother board could be a breack in the curcit board track
