Steering wheel controlsXM
nino
Unread post by nino »
What is the possibility of to connect an aftermarket sony stereo
to the xm mk1 wheel controls.
I've seen there are a number of adapter available on the net,
but what am i looking for?
Some expert help please.
Tnx.
x 1238
Unread post by Peter.N. »
I have a Kenwood CD/Radio in my Mk2, they also make them for Sony. Do a search on the net, just type in 'Citroen XM radio adaptor' or something similar. It consists of some leads and a box controlling the electronics, that you plug in between the radio and the existing leads.
nino
Sure but there seems to be a lot of different
connectro types.
What sould i be looking at on the radio side?
x 1238
Firstly, you have to make sure that the radio is compatable with the adaptor, if you look at the radio details it will tell you if you can use remote operation, if you then order and adaptor kit for that radio to fit a Mk 1 XM it just plugs into your existing leads and the new radio. As long as you order the correct adaptor you cant go wrong.
Try : www.justkenwood.co.uk/stock01/remotes
