Does anybody know which of relays at the rear of main fusebox is front sweeper timer relay. There is plenty of mainly green and black relays. Haynes code don't match with the relay codes. My drizzle switch of sweeper don't work. Sweepers don't either work after I use washer. I think the sweeper timer relay is broken.
Tero
Xantia sweeper timer relay
Aubrey Smith
