Mix Fluids?
Twiss
Mix Fluids?
Unread post by Twiss »
Is it a good or bad idea to mix LHM Fluid with ATF for use in the power streeing system ?
Like drain resovior of ATF and refill with LHM ?
I have a Citroen Zx TD
fastandfurryous
x 4
Why would you want to do that? The spec is ATF. If you fill it with a different fluid, you're likely to knacker all the seals.
If you really want to put LHM in your car, then get a GSA/BX/CX/Xantia/XM etc..
x 94
Unread post by citronut »
LHM is not power steering fluid its hydaulic fluid
regards malcolm
