The windscreen washer has packed up on my wife's R Reg 106. My immmediate thought was fuse ... but all fuses OK. All other electrical systems seem fine but there is no pump sound when operating the front or rear screen washer. Any ideas anyone?
The washer bottle and presumably the motor and pump are tucked inside the offside front wing. Has anybody out there had to get access to the pump and can give me some tips.
Easyrider
Peugeot 106
mbunting
My previous Xantia's washer bottle/pump could easily be seen by looking under the front of the car, the pump is simply a "pull out gently" affair, not forgetting the leads and pipes.
Be careful with the pipes, if the plastic is brittle, sometimes the plastic bit on the pump will snap off - new pump, but they're only a few quid anyway.
fastandfurryous
- x 4
kyle_k
Easyrider
