electrical problem
inferno
electrical problem
Unread post by inferno »
hi all i have a eletrical problem if i turn the ignition on with out starting the engine. the wind screen blower works on all settings and the rear demister.but when i start the engine they dont work but if i turn the engine off but leave the ignition on they work again i havent got a clue will it be a relay???.
allmond
Unread post by allmond »
It would be helpful if you put your model etc of car! :) If it's a Xantia, do a search on ignition switch, they fail and cause these symptoms.
Jamie
inferno
hi sorry its a zx volcane TD
